insert image
insert image
AHoward321
insert image
AHoward321
When using a custom title-block from Autocad what needs to done so that the insert dialog box shows up in Fusion 360? I was informed of a workaround to insert renderings in a drawing  but the work around does not work with custom title-blocks only the OTB title-blocks included with Fusion
jchase123
Hi Alexander,
Unfortunately inserting images into an already defined custom titleblock is not something that has been implemented in Fusion Drawings so far. The only workaround I can possibly think would require you to use AutoCAD to create a custom title-block .DWG file. In this DWG insert your rendering, move the rendering to where you would want to see it in the modeling works-pace of AutoCAD (might take a few tries to position the rendering), upload this .DWGto Fusion and make a drawing from a design using that custom title-block that has the rendering inside of it. This is quite tedious workaround and would not scale well because you would need a custom title-block with each models rendering already inside of it.
Custom Title-blocks/Title-block Authoring - is one of the bigger things we intend to work on improving, once this work gets implemented into Drawings it should become much easier to insert a pre-generated rendering/image into a drawing your working on.
Here is the Drawings Functionality Roadmap: http://www.autodesk.com/products/fusion-360/blog/2d-drawings-check-roadmap/
Best Regards,
Justin Chase
