insert image
insert image
AHoward321
insert image
AHoward321
When using a custom title-block from Autocad what needs to done so that the insert dialog box shows up in Fusion 360? I was informed of a workaround to insert renderings in a drawing  but the work around does not work with custom title-blocks only the OTB title-blocks included with Fusion
paul.clauss
Hi @AHoward321
Thanks for posting! It looks like you are having some difficulty inserting a custom title block created in AutoCAD to a Fusion 360 drawing file. Could you clarify which dialogue box you are referring to as the "insert dialogue box"?
I would start by following the process described in this quick tip video. If you are still having issues, please let me know - I'm happy to continue troubleshooting!
Kind Regards,
Paul Clauss
Product Support Specialist
