Insert Fastener greyed out, not able to use?
tomae
Message 1 of 15
tomae
I was attempting to use the new fastener feature to add some screws to a design.  But that menu item is greyed out for me.  What am I missing?
-Tom
Replies (14)
Message 2 of 15
jhackney1972
You have to be using a Team Hub for your storage.  If you are using Single User Storage, you need to create a Team Hub.  Take a look a this Forum Post to read about a similar issue.
John Hackney, Retired
Message 3 of 15
tomae
Is there any downside to moving my various projects to a team?  I am a single user and have many different projects in Fusion, some personal stuff, some business stuff.  My business projects are already in a separate project, should I just move that to the  team, or move all (both personal and business) to the team?
Message 4 of 15
jhackney1972
That is up to you.  A Team Hub has numerous advantages.  Since you can share access to various Projects in a Team Hub, you can do group design and troubleshooting on the same project.  When working together on a project, the Team Hub protects the files so only one can save changes at one time.  So you could group build a complete assembly, different team members working on different sub-assemblies.
For a business, you can invite clients into your project with "read only" access or other users.  Your imagination is the limit.  I understand that Single User Storage will eventually be phased out so I would switch completely but that is up to you.  I have not used Single User Storage for years and share files, work with other users around the world.
I am a retired designer but I do occasional consulting with other users.  Where we used to have to share projects and files via email now I simple click on their, or my, shared Team Hub and upload or download or work directly in their project on their Team Hub, of course with their permission.
Message 5 of 15
jhackney1972
When you do go to a Team Hub and want to move some or all of your projects to it, please read this webpage for instructions.
Message 6 of 15
tomae
How long should this process take (to move all projects to the team hub)?  I pushed go and it has been spinning with "72" in the circle for like an hour.  If I look at that team it says it is empty...
-Tom
Message 7 of 15
jhackney1972
It depends on how much data has to be transferred.  It has been years since I did it so I really cannot say.
Message 8 of 15
tomae
Well, it finally failed saying it could not create a project.  Not sure where to go next.
Message 9 of 15
jhackney1972
The process can be done by Project.  If you have more than one Project, try doing one at a time.  I create a Project in my old Single User Storage to test, screen shot shown below.
Message 10 of 15
tomae
Thanks, trying that now...
Message 11 of 15
tomae
Ok, that seemed to work!  I am able to access the fasteners as well.  Thanks,
-Tom
Message 12 of 15
mmckay
Why can't Autodesk activate Insert Fastener in single user hub also?
Message 13 of 15
jhackney1972
I am not an Autodesk Developer but my guess is the Insert Fastener requires a place to generate and store the fasteners used.  In a Team Environment they can easily create a Project location for this that is accessible for all present and future assembly models.  This is not as easy to do in a Single User Environment.
Message 14 of 15
nkukich
Observer
Observer
Excuse me?  I need to convert to your onerous cloud storage to add fasteners to my designs?
What planet are you from where this is acceptable?
@nkukichthis post has been edited due to Community Rules & Etiquette violation.
Message 15 of 15
TheCADWhisperer
@nkukich
Cloud storage has always been a focus of Fusion since the beginning.
But it is trivially easy to insert a fastener and break the link without ever saving to the cloud.
You can keep all of your work local.
