Incorrect pattern cut
jaimepajaroloco
Message 1 of 10
jaimepajaroloco
Can anyone tell me if I am doing something wrong of there is a kind bug in the simple pattern?
It is creating line where there are not supposed to be.
See the file attached.
Replies (9)
Message 2 of 10
jhackney1972
I am with you, this seems to be a Fusion 360 bug.  You can workaround it by doing both extrusion separately and then two patterns.
@jeff_strater , what do you think about this issue?  Model is attached with my workaround.
John Hackney, Retired
Message 3 of 10
Rohan.bongale
Thank you for addressing the issue, I am able to reproduce the issue and I have logged a bug and addressed it to the development team.
Thank you,
Best Regards
Rohan Bongale | Senior QA Engineer  | Autodesk India Pvt Ltd.
P. 20 6680 4444 | rohan.bongale@autodesk.com
Message 4 of 10
mango.freund
Hello @jaimepajaroloco , please don't break the guilt stick about fusion too quickly.
first take a look at your formula. that is far from correct.
you have not selected the middle in the drawing! that is unfavorable.
As the colleague @jhackney1972 wrote, in your case it is better to select an extrusion and enter the height correctly. the height in this case is not 700mm - there is the trap.
I would like to give you one more tip - get the free "joinercad" app from the fusionstore.
greetings mango
Message 5 of 10
rushabhthakkar_910
@jhackney1972 and @mango.freund , If I have correctly understood the Issue, Can the pattern be made by using Pattern on Path option and not Rectangular pattern..? As shown in this Screencast Video..?
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 6 of 10
rushabhthakkar_910
Also I am able to Create the Pattern using Rectangular Pattern too... Can be seen in this Screencast Video...
Thanks and Regards,
Rushabh Thakkar.
Message 7 of 10
jaimepajaroloco
Thank you for the tips, but I still don't understand how my wrong formula creates 2 extra lines in the pattern when I clearly specify 3 not 5. I am just using the formula to move the lines around when I extend or contract the height of the cabinet.
I will check that plugging for sure.
Thank you.
Message 8 of 10
jaimepajaroloco
Thanks, but my issue is that with my file when I select 3 patterns it makes 5 at different heights. I don't understand how my bad formula affect to the number of instances.
thanks
Message 9 of 10
rushabhthakkar_910
I have portrayed Pattern in your file only... Just moved the History 2 steps back words when the pattern was not created.. And than created a Fresh one..
Thanks and Regards,
Rushabh Thakkar.
Message 10 of 10
jaimepajaroloco
Thanks, I followed your steps and repeat the operation using the same ''bad formula'' and I was able to do it.
I am not sure what happened yesterday night. Hopefully it was only my thickass fingers and not a bug.
