making polygon spirals without sketching every line
hobby2005
Message 1 of 8
hobby2005
any way to make these https://www.tutorialsandyou.com/python/how-to-draw-spiral-square-and-star-in-python-turtle-12.html
spir.JPG  without drawing every line     i suspect an equstion would work but i have no idea where to start
Replies (7)
Message 2 of 8
TrippyLighting
If you are looking into programming this in Python, the forum has an API section where you might get better responses.
@MichaelT_123 any interest in chiming in ?
Message 3 of 8
mango.freund
Hello, if I had this task I would start with a polygon. Draw construction lines from the center over the corners. then determine with which degree the first line is to be drawn. The steeper it is, the fewer spirals are required. make sure that the lines with constrains lie on the lines. then draw the lines with arrange on path. yes, that has to be done with each segment and well, - greetings mango
Message 4 of 8
mango.freund
pardon i  want stop, but i have send it --- i am sorry.
Message 5 of 8
MichaelT_123
Hi Mr  TippyLighting,
 If the problem was presented by 'young && bright'  my 'chiming' would cause the disservice to his/her development.
This simple geometric exercise should not be difficult, and as such even encouraged as the valuable exercise of writing few lines of the code required.
However if it was presented by ... 'old  && #art' ... it is to late!
Thank You For The Trust In Me 😁
MichaelT
MichaelT
Message 6 of 8
hobby2005
hello thanks for the help  i should post to API     I'm not very good with code   and suspected from the start an equation was in order
Message 7 of 8
hobby2005
yeah i figured that out last night thinking about it     if I know the distance between each coil i could  pattern points and join it with lines
Message 8 of 8
daniel_lyall
@MichaelT_123 What?
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
