Hi
I`ve been reprimanded for creating parts then bring them into the design. At the moment I brought
an assembly in (Linear_Assembly) and wanted to fix it to (Mount_Plate_LinearZ_to_THK)
In Fusion can you dimension an assembly to another component after you joint them to establish a precise
location. Or again should I have created a sketch for the Linear_Assembly in the current design then extruded it.
