3D Print conversion
3D Print conversion
3D Print conversion
Is there a way to convert a 3D print file for a M3D Micro Printer? Any help with this matter would be greatly appreciated.
paul.clauss
Hi @Anonymous
Thanks for posting! It looks like you have some questions about creating a file for 3D printing with the M3D Micro Printer.
Are you using the M3D software as your printing utility? If so, it looks like it will support both STL and OBJ files types. Fusion 360 can export both STL and OBJ files to your local machine. The instructions to do so are included at this link - I would likely use the option to right click bodies/components in the browser tree of Fusion and select "Save as STL."
Hopefully this helps! Please let me know if you have any questions.
Paul Clauss
Product Support Specialist
Thanks Paul!
