- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
workflow:
- You find the last file you worked on via "My Recent Data" in the data panel.
- You want to go to the root folder/parent folder of that file, to find other related files.
- You can see the file path in the description of the file, but you are not allowed to click the file path.
Wouldn't it be nice to be able to click on the file path for your file, and be directed to the root folder of that file (or other places in the file path, depending of where you click) in the same way as on every folder manager on a computer?
maybe even more useful would be to be able to do this when you get search results in the data panel. (Which is basically the same, coding wise)
Attached image to illustrate
