Impossible to create sphere in position
Message 1 of 48
When I create a sphere it forces me to place the sphere in a new, blank sketch, which is useless because there is no way to reference the things I've already laid out in my sketches.  It only snaps to the blank sketch grid.
I already made a sketch and placed a point where I want the sphere, but it won't let me create a sphere on that point.  I don't understand how this is supposed to work.
Also if I click edit feature, there is no way to select a different initial point for the sphere.
Also I know I can move a sphere after creation using Point to point, but then this doesn't get updated if i alter any sketches parametrically.  Moves are not recorded parametrically.
Replies (47)
Message 41 of 48
WolfRG
Community Visitor
Community Visitor
I read the thread and I'm having the same problem...8 years after the original complaint.   In short, I made a sketch (on the face of a component) and added a rectangle to identify the four points where I needed to place spheres but the system only recognizes the 1st sphere location and thereafter the sketch is not selectable (while in the sphere placement mode).   My work-around is to make a sketch for each sphere.   The sketches don't need to have anything within but somehow that allows the snap to work.   Please advise.
Message 42 of 48
etfrench
Just draw a circle at each point of the rectangle.  Extend two sides of the rectangle to the circumferences of the circles:
Revolve each semicircle to create the spheres:
ETFrench
Message 43 of 48
TheCADWhisperer
@WolfRG wrote:
 Please advise.
@WolfRG
Message 44 of 48
s21Q9J8A
I'm not interested in a work-around.  Why isn't this fixed 10 years later?????????????????????????????????????????????????????????????????????????????????????????????????????????????
Message 45 of 48
jhackney1972
I do not see any issue creating a Primitive Sphere on a predefined sketch point.  Even if I never would use a Primitive, it seems you just are not holding your mouth right when you create one.  Video will show you how.
John Hackney, Retired
Message 46 of 48
jhackney1972
Well, does my video solve your placing of a Primitive Sphere issue?  This is not a work-around so you cannot say it does not work with standard commands.
Message 47 of 48
etfrench
That doesn't work for me 😀
ETFrench
Message 48 of 48
jhackney1972
It is probably because I use the "hated" Auto Project Edges on Reference option in Preferences.  A lot of users on the Forum preach against this setting but I love it.  When trying to select snap points, with this setting, is important to be looking normal to the sketch plane as you did.  Hope this does it for you.
