Improving my workflow.
onlineEVLCU
onlineEVLCU
I after some tips and / or validation on improving my work flow for the attached project. I saw something similar on Reddit and wanted to recreate the piece to improve my skills. I have only been using Fusion for the last 8 months, so be gentle. Thanks
https://a360.co/44RRZUf
davebYYPCU
What works, is all you need.
I did not understand the 2nd to last rectangular pattern, change pattern count to floor(Verticle_Count + 1) and it still works, (despite the preview) without the last pattern command.
Then you can Delete the last pattern icon.
(Will speed things up.  For the future - Fusion does not do well with overlapping geometry)
If being real picky, you can delete the first circular pattern, as well, edit the last circular pattern to pick up both Revolve cuts at the same time.
I do understand the baby steps, but Fusion can do advanced just the same.  Efficiency comes from short timelines.
Might help...
onlineEVLCU
Thanks Dave for your feedback. Just what I was looking for.
