Importing SolidWorks designs to Fusion 360
Message 1 of 8
I am a very new user. Trying to migrate to Fusion 360 from Solidworks.
After uploading a Solidworks Model to my project, I am unable to open it properly.
If I double-click it or open it in any other way I cannot work on it. Once I click the work area the design disappears.
After viewing a bunch of tutorials, I still cannot figure out what I am doing wrong.
I attached a screen cast.
Thanks, in advance,
Eric.
Replies (7)
Message 2 of 8
JDMather
What version of SolidWorks?  2016? 2017?
Can you attach example file(s) here?
Message 3 of 8
I tried several files from several SolidWorks versions that I downloaded from GrabCad.
I does not seems to be an issue of the version.
Message 4 of 8
I have uploaded a new screencast explaining the issue.
I included Audio explanation.
Also attached SolidWorks models that were used.
Arik.
Message 5 of 8
TheCADWhisperer
Did you upload your part files and assembly files to a folder in your data panel before attempting to open in Fusion?
Message 6 of 8
Yes!
Message 7 of 8
JDMather
There is extra "rubbish" in the folder that you don't need.
I will try to remember to create a video tomorrow.
Message 8 of 8
Sorry but I don't understand the answer: I tried again after deleting everything else except the solidworks files from the directories. I see exactly the same problem! Is it possible to have this solved?
