Importing SLDPRT, can't edit sketch.
owarner5SRK2
owarner5SRK2
I am importing a SLDPRT file. I need to edit the dimensions, and I can't seem to be able to. I can edit the extrude feature, but not the simple sketch dimensions. Is this even possible?
JamieGilchrist
Hi owarner5SRK2,
importing a SWX file translates just the 3D geometry of the model, it's essentially like a STEP file.  You can modify the geometry using the push/pull command, but you won't be able to edit it parametrically without rebuilding it in Fusion.
What are you looking to adjust?  There are a number of things you can do quickly, depending on your intent.
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
owarner5SRK2
Thanks for the reply. I figured as much. I needed to change the X and Y dimensions, and also the hole pattern on the model top. I did end up rebuilding it.
