Sheet Metal - How do I create this shape?
nathan.regnierlange
Message 1 of 11
nathan.regnierlange
 So this is what I'm trying to make.
But I can only get this far, and I can't figure out how to make that last flange go straight down and terminate level at the bottom
Replies (10)
Message 2 of 11
TheCADWhisperer
Can you File>Export and then Attach your *.f3d file here?
Message 3 of 11
nathan.regnierlange
Here you go!
Message 4 of 11
etfrench
Just measure the difference between the high side and the low side and add that on to each end:
ETFrench
Message 5 of 11
nathan.regnierlange
That's not the outcome I was looking for, and it's an ugly, time consuming workaround.
Message 6 of 11
etfrench
Perhaps explaining in detail what you're looking for would help.
ETFrench
Message 7 of 11
TheCADWhisperer
Maybe something like this?  (see attached)
Reverse.PNGThicknessThickness
Message 8 of 11
I_Forge_KC
Here is another solution. To be up front, this creates weird artifacts because the deformation in the corners is removed by the method I used. It also induces bevel in the flat stock edges because we remove the distortion. It appears your material will be cardboard - so these deformations aren't a big deal (paper bends). Use at your own peril, though.
Take a look at the attached file.
1. I created a workplane just up from the bottom face
2. I extruded the skinny face of the two flanges to the workplane - if you didn't use the offset plane you'd be in trouble because the flanges would boolean to the base (thus preventing you from unfolding)
3. I created a workplane at the front
4. I used replace face to change the location of the angled faces
5. Rinse and repeat on the back side.
K. Cornett
Generative Design Consultant / Trainer
Message 9 of 11
TheCADWhisperer
I guess not?
Message 10 of 11
nathan.regnierlange
Sorry, I've been really busy. But both of those solutions look great, I just haven't had a chance to look at the files.
Message 11 of 11
TheCADWhisperer
@nathan.regnierlange wrote:
... But both of those solutions look great, I just haven't had a chance to look at the files.
Only one of them is correct geometry.
