Importing CSV file or similar to populate an array of plaques
I've tried to find a way to import text into fusion 360.  Specifically, I'd like to take text from an Excel file, csv file or something similar and populate the surface of 16 plagues arrayed for CNC engraving.  Each plague has unique text which would come from the file (Excel, CSV, etc).  This process would be repeated dozens of times hence the desire to find a way to auto populate the text into Fusion 360.
Does anyone have any insight into how this might be accomplished?
Shane
innovatenate
Autodesk Support
Autodesk Support
You would probably need to dive into the API and write a custom script that would import your coordinates and text from an excel file.
Importing data from a CSV file:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-1c19f064-fdf0-11e4-a863-f8b156d7cd97
Create Sketch Text:
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/ENU/Fusion-360-API/files/Sketc...
If programming isn't your thing, you may consider discussing your customization needs with an Autodesk Reseller. I hope this helps!
Nathan Chandler
Principal Specialist
I_Forge_KC
Or someone from the Services Marketplace!
K. Cornett
Generative Design Consultant / Trainer
Alan.r.beswick
Apologies for not replying sooner.
Too hard, so do it backwards
I'd like to take text and populate the surface WITH 16 plagues arrayed for CNC engraving.
In the description below, there is a little programming to be done. I will give printf examples, as printf is available in many C like languages. Python and even FORTRAN have equivalents. I will use the unix utility awk.
Prepare the text, say triple spaced. I used 100 random names from https://www.name-generator.org.uk/quick/
awk '{printf "%s\n\n\n", $0}' randomnames.txt
Create a Fusion 360 text box, wide enough to take the name without folding it. The formatted text will flow out of the bottom of the text box in a controlled manner
Create the plaque over the first line of names, then make a rectangular array to create the multiple tags
Hint: parameterise the text height
That will give ONE column of plaques, any font, centre justified. To get multiple columns, prepare the text using a monospaced font like courier.
awk '{printf "%-30s", $0} NR%3 == 0 {print ""}' randomnames.txt
mini:scratch atnt$
Lowri Stuart                  Kareena Ryan                  Kalem Hewitt
Hallam Redfern                Rita Zamora                   Kayne Eastwood
Ayaana Simmons                Massimo Coates                Gage Hunt
Jazmin Stanley Brody Spencer Abdul Muir Tayyib Dunn Konnor Mcdermott Dante Leal Weronika Wagner Jemima Atherton Valerie Tran
Use a two dimensional array of plaques and job done.
With a slightly more complex printf statement, you can get centre justified text on the 2D array of plaques.
Export and dxf and laser it.
Hopefully, there is a sample attached.
Alan.r.beswick
Oops, correct file attached
