Importing and Scaling
knightersunit345
knightersunit345
Hello, I am trying to import an stl file from Tinkercad but when it goes into fusion 360, the model is 10 times as big(ei. 72.85 mm gets changed to 728.50 mm).
I use the Scale tool to scale the model back down to 10% but then the model is just floating is space above the work plane. This is very annoying and I want to know if there is a tool that can snap the model back down to the work plane after I have re-scaled it?
you can use modify > align.... Select the the body/component and choose From as your body / component & to point as the orgin
dsouzasujay
Hi @knightersunit345 ,
Mesh files wont store unit information, If you directly open a .stl file in fusion 360 then it will import in cm.
Next time, while importing a .stl file in Fusion 360.
Create a new document and Use Insert > Insert Mesh.
Select appropriate unit type and then hit ok.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
