'pattern type' option is not there in my mirror command.
rsunghun
rsunghun
hello, I was searching for a way to mirror component. I see there is a 'pattern type' in mirror option other's video tutorials but it's not there in my fusion360. How do I mirror components and groups?
thank you
hello, when you use mirror tool in sketch interface, there will be no option like pattern type because u have only the sketch entity. use mirror tool from the design interface, I have attached some image for reference. pls check
rsunghun
thank you for the reply. In fact I'm not in the sketch mode and still there is no pattern type.
KristianLaholm
You have Capture Design History (timeline) turned off and can only mirror faces.
To be able to mirror bodies, features and others you need to have the timeline on.
rsunghun
this was it! thank you!
