pashkovada
Message 1 of 9
pashkovada
Hello everyone!
I have chair from internet. The model looks like steel, and doesn't use its own materials.
When i put on F360 materials render in cloud or local render is failed.
There is .obj with .mtl and .jpeg in one folder.
I did everything from this topic, but it doesnt work!
https://forums.autodesk.com/t5/fusion-360-support/importing-a-obj-file-with-associated-mtl-and-jpg/m...
Help me please put on materials and render it correctly!
Replies (8)
Message 2 of 9
laughingcreek
which material are you applying?  have you tried a different material?
can you attach the model to a post?
Message 3 of 9
pashkovada
Yes, I've tried several materials.
Message 4 of 9
laughingcreek
rendering ok for me.  might be better to attach your.f3d file-
Message 5 of 9
pashkovada
the same problem. importing with metal material..
Message 6 of 9
pashkovada
Без имени-2.jpgThe Same problem is with another model. It is saved in 3ds max with mtl files. When it's opened in fusion360, the base material is overlaid. when applied to the F3d material model, the render looks like a broken figure.
Message 7 of 9
Bunga777
I have downloaded the data.
I tried it too, but I tried it with yellow paint and got this result.
Something is wrong, but I am still unsure what is wrong.
Message 8 of 9
TrippyLighting
@Bunga777 @pashkovada The cloud and local render modes have a problem with rendering imported meshes.
Canvas rendering usually returns good results.
Similar issues are reported here and here.
@Phil.E
Message 9 of 9
Phil.E
Thanks.
(FUS-115343)
Phil Eichmiller
Software Engineer
Quality Assurance
