Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Imported fusion component is fixed in present design
1 REPLY 1
ea425019
175 Views, 1 Reply
This linkage system does not move or situate itself properly (its own internal joints) when I import it anywhere (more than one design attempted).  When viewed as it's own, the 'support structure' file shows that it works well. You can grab the broad center link and move it around to see.  What is going on?
The image shows the linkage going on a module. I cannot attach the module here, too large of a file, but I attached a blank file (demonstrated inserted component.f3z) to accept the import, with the same error.
Another issue I see is that the files attached here are ".f3z"  and "F3d" which is strange to me, I felt previously that it was only one suffix.
Eric
1 REPLY 1
dsouzasujay
in reply to: ea425019
Duplicate POST
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
