How do I resize an entire project ?
penelope.pomey
Observer Observer
penelope.pomey
Observer
Observer
I have been working on a project with multiple bodies for a while and I realized too late that I did everything in mm instead of cm so everything is 10x smaller than it should be. Is there a better way than having to go in each sketches to multiply everything by 10?
I'm desperate help!
aliobidi
Hi ,
when you finish your work just turn off the timeline then scale
laughingcreek
@aliobidi - why turn off the time line?  just scale, then you can always roll back to make edits.
jhackney1972
By Project, I am assuming you really are referring to an assembly.  If you are, then the process can be done by using them method outlined in my Screencast.  Please note, all joints, motions, etc will be lost so save your original.  Using this method it will keep all your assembly components in their original position.
John Hackney, Retired
aliobidi
if he have multiple bodies and components and linked projects .. this is the better way
for just bodies or components just scale directly  .
laughingcreek
why is it better to lose your history when you can do the exact same things with the history on?  what is it you can't do with the history on?
aliobidi
watch this
you can't scale linked project in the main one and it's take a time if you going to origin project to scale then update
and if you break link sometimes you have issue like in recording
so why not if you finish your work to lose the timeline after save a version with last step in timeline
