imported dxf can't snap to items while editing
Message 1 of 23
I imported a dxf and it needs work  but I can't snap to any of the geomerty to fix it . The items when slected form one chain but are not shaded closed .
Replies (22)
Message 2 of 23
HughesTooling
Some splines don't work in Fusion, can you attach a DXF you're having trouble with. Does your problem look anything like the problems in this thread How-to-create-a-face-on-a-imported-dxf
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 23
nope  nothing is closed . here is the file .
Message 4 of 23
HughesTooling
Although your curves look different to the other thread I think they have the same "G1 discontinuous" type of splines that Fusion can't work with. I don't know if @Maowen_Zhang could take a look at your file..
Mark
Mark Hughes
Message 5 of 23
Maowen_Zhang
@Anonymous, @HughesTooling, thanks for sharing the issue with us!
We checked that I could snap geometry to the imported splines, and the sketch profiles also shows up. Is this what you see? If not, could you provide some more info about it?
If you do can't see the profile, could you try delete the special spline as below to check whether profiles show up?
Lori Zhang (Fusion Development)
Message 6 of 23
HughesTooling
The problem is you can't edit the splines. If you edit the sketch and click on one of the splines you don't get any handles to make modifications. Also the points on the spline don't do anything, if you find the end point, point you can move the spline but moving the other points on the spline has no effect.
Mark.
Mark Hughes
Message 7 of 23
skull problem this is what I get and no I can snap to it besides the seam point , I am running windows ten !
Message 8 of 23
HughesTooling
Are you in wire frame mode.
Mark
Mark Hughes
Message 9 of 23
No I am not ..
Message 10 of 23
HughesTooling
I've tried on Win7 and 8 and all's OK. Is there a newer driver available for you graphics card, I've seen a few posts similar to this and it was down to that.
Mark
Mark Hughes
Message 11 of 23
that dxf was an export from fusion and that mess is not what I am working with here is the archive file . the video drivers are up to date and I know win 10 is not stable with cad programs . I have seen my share of bugs with it but that is what I am running for a workstation .
tony
Message 12 of 23
HughesTooling
I opened your file and it doesn't work for me either. Is this a version of the DXF you've edited in Fusion, if it is at what point did it stop shading?
Mark
Mark Hughes
Message 13 of 23
the dxf is was an imported into rhino and exported as 2004 natral from rhino . The file was uploaded to fusion and didn't shade from the start .
Tony
Message 14 of 23
HughesTooling
Can you attache the Rhino file please, you might need to put it in a zip file to attach it to this forum. I'd like to experiment with the splines in Rhino to see if I can figure out if the a way to get them to export in a type that Fusion will work with.
Thanks Mark.
Mark Hughes
Message 15 of 23
the dxf is something i got from cnczone awhile back and that export setting is something i know works it is more then likly the orginal dxf file . but if you want to play with it here it is .
Tony
Message 16 of 23
HughesTooling
Do you have the Rhino 3dm file, reimporting the DXF might add more problems.
Mark
Mark Hughes
Message 17 of 23
I do not have problems with files from rhino when curves are made within that program .
tony
Message 18 of 23
HughesTooling
I imported the file into Rhino, exploded the curves then exported as DXF and now it works, it looks like Fusion doesn't like joined NURBS curves. Fusion file attached.
Mark
Mark Hughes
Message 19 of 23
what version of rhino are you using ? I am stuck on 4 at the moment .
Tony
Message 20 of 23
HughesTooling
I'm using V5, I setup the DXF export like this.
Mark
Mark Hughes
