imported dxf can't snap to items while editing
Message 1 of 23
I imported a dxf and it needs work  but I can't snap to any of the geomerty to fix it . The items when slected form one chain but are not shaded closed .
Replies (22)
Message 21 of 23
ok nice I may grab the update to 5 at some point . thank you for the help .
Tony
Message 22 of 23
Maowen_Zhang
I see. Yes, can't edit the spline, the imported spline has only one fit point created. Will check with others about whether we could support it.
About no profile (sharded), have you try deleting the special internal spline?
Lori Zhang (Fusion Development)
Message 23 of 23
HughesTooling
Hi Lori
If you look a post #15 in this thread there's another DXF attached that Tony edited in Rhino, if you import that the splines don't shade. I found if I opened the DXF file in Rhino and ran explode on the splines it would then load and shade in Fusion. It looks like Fusion doesn't like splines that are joined to more splines.
Mark
Mark Hughes
Owner, Hughes Tooling
