- Mute
- Permalink
- Report
If you try inserting an SVG file before starting a sketch you need to select a plane for the SVG to use. After selecting the plane the Sketch Palette appears and covers the SVG dialog, you have to select insert SVG again to get it on top of the Sketch Palette.
Mark.
Mark Hughes
Owner, Hughes Tooling
