Import dimensions from model
Starting into drawings. Why isn't there an option (can't find one!) to automatically pull the model/sketch dimensions into the drawing? It's a right faff adding them all back into the drawing.
Would rather they were all added and you can delete what you don't want rather than spend time adding. Much easier to select and delete 🙂
jhackney1972
Fusion 360 does not have this feature "yet".  You will find this in the higher end Autodesk application Inventor.
John Hackney, Retired
