How to make hole on the sketch?
I started learning Fusion 360. I can't understand how to create a sketch with hole. Like "o" character for example...
Thanks for advice.
laughingcreek
Are you talking about sketching a circle?
can you attach a picture or hand sketch of what your trying to achieve?  Your question is confusing because you don't put a "hole" in a sketch, although you can put one in a solid.
Of course I can make a hole in a solid body. But sometime it could be easier to have a sketch with hole. For example like this. How I can make a hole inside this sketch? How to cut central part?
davebYYPCU
You draw a circle.  Putting a circle in that sketch will not cut a hole in the blue shading, it will make the shading break into separate pieces for you to select as required.
Might help...
jhackney1972
I am hoping the attached Screencast will give you the information you need.  Looking at you screen capture, you need to start constraining your sketches with dimensions and constrains.
John Hackney, Retired
Understood... I worked a lot with adobe illustrator some time ago. And it was easy to make sketches with holes. In fusion 360 I also saw sketches with holes when I insert a text. As all letters with holes. I tought I also can make figures with holes in blue shading.
