I'm already apologizing for my crappy english, but I was never a very good student in the English classes.
This is my first question here, so let's go!
I've to create a new design for a tennis court. I drew something in Fusion 360 and made a render, so far so good. This is the 'Test 4' image.
My co-worker wants me te create a render with an 'environment' of the existing state of the buildings.
The 'environment' is no HDRI file, (this would solve everything) but a 3d file. .obj and .mtl. This is the 'Current situation' image.
Long story short: I want these 2 3D-files together in 1 Fusion file.
Is there a way to import a 3d file which includes textures and colors into Fusion 360?
Solved by TrippyLighting. Go to Solution.
Nope, unfortunately, this can not be done.
You can try to export the FUiosn 360 file into .fbx format, which is a mesh format, but. am not sure this includes textures from Fusion 360.
Then you could merge the two files in another application e.g. Blender and create the render there.
