Import 2d drawings
Import 2d drawings
不适用
6,513 次查看
6 条回复
1 条消息(共 7 条)
Import 2d drawings
不适用
We have 40 years worth of 2d drawings, with no models. Is there no way to load these drawing into f360. I tried saving them as dwg files but did could not get text or dimensions to import. Also. In the Android companion app I could. Not view the drawings at all.
0 个赞
6,514 次查看
6 条回复
回复 (6)
2 条消息(共 7 条)
cmiller66
Hi patvburden,
If I am understanding the request correctly, what you are trying to do will not work. Fusion is not a 2D drawing (dwg file format) editor.  It is primarily a 3D design application (f3d file format) which has drawings functionality (place views of the model, dimension them, etc.) in its own drawing file (f2d file format).  If the DWG you have has 3D geometry in it, that can be uploaded to Fusion and opened, but we can't open/edit existing legacy 2D dwg files.
Chris
0 个赞
3 条消息(共 7 条)
不适用
0 个赞
4 条消息(共 7 条)
Zartimus
Community Visitor
Community Visitor
It's a feature that would be greatly appreciated as more people use Fusion 360 for 3d printing. A vector line drawing imported into Fusion 360 as a 2d sketch that can be extruded would be a very useful thing. I was surprised to find this feature missing. It makes me turn away from the product in search of another that can do this seemingly simple thing.
5 条消息(共 7 条)
Zartimus
Community Visitor
Community Visitor
Actually it seems you can sorta do it in a round about way though the SVG vector graphics filetype. You can trace your bitmap in illustrator or Inkscape (like below) and plop it into Fusion 360 according to this tutorial.
https://www.lifewire.com/turn-2d-image-into-3d-model-2293
0 个赞
6 条消息(共 7 条)
henrycasson
Maybe I do not completely understand the question. I have imported a lot of legacy stuff by saving 2d info as DXF. If you have DWgs you can easily do that. I use Draftsight.  Dimensions could be adjusted there if needed.
The DXF can be imported into a sketch, and then you are able to go back into 3d.
Henry.
retired Doc.. should have been an engineer.
7 条消息(共 7 条)
cmiller66
Hi carrdav,
What file format is the 2D drawing you want to import?  If you have a DXF you can import this into your design as Sketch geometry using this option:Insert.png
Chris
0 个赞
