tool bar not docking
After the update on March 28th my tool bar will not dock. I can not even collapse it.Also the browser menu went from translucent to opaque. Are there setting that can be changed to correct this issue.  Also now when I open Fusion I never know where any of the menus are goin to be located. I have to move everything back to where I had them before I can start work.
Discussion_Admin
If you can let me know what product you are using I can move you post to the appropriate forum for you.
Discussion_Admin
I am using Fusion 360
Edited by
Discussion_Admin
HughesTooling
Click the title bar and drag to the edge of the screen, when the pointer reaches the edge off the screen you should get a green line just release the button and it should dock.
Mark
Mark Hughes
Owner, Hughes Tooling
dstevenslv
Mine hasn't docked or collapsed for a while now, a couple of months or so.  I work around it, it's somewhat of an inconvenience.
frank_f
I'm having the same issue. I tried Mark's suggestion but there is no green line.
Never mind. It's all in how you grab the header. It took me about a dozen tries on the Browser handle before I could get it to dock. Thanks Mark.
