identify selected objects in dialog
designingberlin
designingberlin
I've a question concerning most of the timeline objects like extrude, combine ...
Once the operation is complete and I want to revisit it, I've no way to identify my selected object (let it be a sketch circle or a body). I can only see how many objects are selected. Is there a way to highlight the selected objects (or otherwise visualize, get the name or sketchname ...)? Sometimes it's hard to understand and modify some operations if you can't identify the objects being involved.
Stefan
patilsm
Hi Stefan,
As I understand your question your concern about once we do extrude for multiple object selection just like multiple circular sketch and compute command.
If I want to revisit same extrude operation, so I need to go back in Edit extrude feature from time line and  there you see only the number of object evolve where you don't see circular sketch selected....This is your question then.......my answer is Yes, we can see selected object by pressing Ctrl key you can hide the preview for extrude and see selected object file which is get highlighted in blue color and if require you can add any new or delete any object.
Sagar
Sagar Patil
Software Engineer
Quality Assurance
JamieGilchrist
hi Stephan,
as Sagar suggests, currently you can use the Ctrl (or Command key on mac) to effectively roll back the built geometry to see your selections.
We are looking at enhancing this experience in the future so you have a more "surgical" method to edit your selection sets in the context of a command or editing a command.  This would likely include some sort of "selection list" UI to see each object participating in the command along with a means to easily remove or add individual components to the active command.  We don't have any specific time when this may show up in Fusion, but it is something we are looking at.
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
designingberlin
Hi Sagar,
thanks for your suggestions. I know this trick and it works well for extrusions and even fillets.
I'm mainly running into issues, when joining several smaller bodies into one bigger body. What's the target body and what are the tools. It's may be very important to know.
It's especially true for joining multiple bodies, since the result geometry does not depend on the selection order, but the name of the final object does.
Stefan
