moving objects in sync
i have a bunch of components etc together in one huge group all formatted to the right formation etc, i want to rigid align one from this group to another separate component, how do i keep the group together so when it moves to the other component to coincident everything else moves too?
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
Without seeing the model it is a bit tough to comment - but if you first create joints inbetween all the sub-components within the component, they should move together, when you go to do the rigid group (as they are now constrained to each other). If the entire component will be rigidly grouped - try to use the Rigid Group tool from the Assemble menu and select all the components within the one. Then, when you go to create the rigid group (which will move the one component) it will animate showing only the one moving, BUT when you hit OK it all should move together.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
James Youmatz
General Adoption Manager | Informed Design
