Ideas of suggestions...
SimonPlatten
SimonPlatten
I'm working on:
This is a project which eventually I will 3D print, I would like to print the pole separately then the platform in the middle with the fins as another print.  I intend to add more platforms to the pole.  The reason for this post is I would like ideas or suggestions on how to fit the platforms at various stages on the pole, I want them to be a specific locations locked into position so when they move the pole moves to, so it will eventually be one fixed object.
g-andresen
You can arrange the platform (component) in a pattern (rectangular) several times on the shaft.
günther
SimonPlatten
Thank you, can you elaborate please?
g-andresen
try this and fix them the way you like (screw...)
günther
