I've got a red line I cannot select or remove
jfhext
jfhext
Here's a screenshot:
I think that it arose when I edited a sketch that something else relied on, and ended up with a reference to cached geometry. I delete the thing that referenced it, but cannot figure out how to make it go away.
I've attached the Fusion file. I'd hoped I could answer this myself, but the Fusion help on line-colors doesn't even mention red (although I have to admit that this line isn't just in a sketch -- it appears no matter what I do!)
jhackney1972
I can find no Red Line in the model.  If you still see it, indicate the location within the model.
John Hackney, Retired
bwalker145
I don't see it on my side either.
Have you tried restarting Fusion? If it's just a graphic artifact and not inherent to the model, that might help.
jfhext
I guess I should accept this as a solution, because it suggested to me that what I was seeing was not a property of the design, but of Fusion's current display of the design. So I closed Fusion and restarted, and the red line disappeared.
Until recently, I've been really impressed with Fusion. This kind of thing disheartens me.
But I appreciate your taking a look and indirectly pointing me in the right direction ("It's not you...it's Fusion.")
