I need the camera to stop snapping around whenever i do a filet or chamfer.
Dunndor
Dunndor
I need this funsction ASAP. I am getting dizzy from the camera snapping around to whatever is highlighted whever i hit a function. I Demand a fix for this ASAP. I WILL SNAP/MOVE CAMERA WHEN I NEED TO. Not all the time. This is possibly your worst adition to the program yet. If you do not change this I will never use this program again.
jeff_strater
The camera changes you are seeing - are they related to sketches at all?  That is, are you seeing them either when entering a sketch (it was not clear if you were talking about sketch fillet and chamfer, or modeling fillet and chamfer), or when exiting a sketch (if you are in a sketch, and you do a solid fillet or chamfer, it will exit the sketch).
If it is sketch-related, then, to be completely honest, I agree with you.  I find this annoying.  But, the good news is you can turn it off (which I do):
I hope this is your problem and that this fixes it.
Jeff Strater (Fusion modeling)
Jeff Strater
Engineering Director
Dunndor
OH THANK YOU! it was driving me nuts!
Actually I kinda like that feature myself for working with sketches on different faces. I can see how it would be annoying in a more complex model or assembly.
Analias
I too found this feature to be annoying,  The automatic zoom in was nice. What was disorientating was the rotation of the view at the same time.  Which typically left me looking at my desired feature 90 degrees off axis, and often moving the area that I wanted to do my next operation in off view.  It would be much more usefull if it didn't do that.
Now that I have disabled this option it is better. I still find myself doing a manual look at, which doesn't have the same behavior.
-Freeman
