Assembly: Component orientation renders flipped
Sometimes when I go to make a joint connection the part will render correctly, but when you accept it will flip it. Then you have to go back in and flip it so it renders WRONG and when you accept it, it flips the right way.
I think my forum posting about problems to using Fusion ratio is approaching 3:1
O.Tan
Would be better if you can give us a screencast or screenshot, right now I have no idea what joints are you using and if you're using the correct joint for your application or not.
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
Hi, this is a bug report because it previews opposite of what it actually
applies.
O.Tan
Well then I guess you'll have to wait for an Autodesk employee to reply then as I have no idea what bug report you've filled.
Also, they'll probably reply slower as it's holiday period (http://forums.autodesk.com/t5/sketching-sculpting-modeling-and/autodesk-holiday-12-24-14-1-1-15/td-p...
Omar Tan
Malaysia
Mike.Zhang
Hi there,
Could you share your model here, let me analyze it.
Or send me a mail attachment: jiangang.zhang@autodesk.com
Thanks.
Mike.Zhang
SQA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
