Message 1 of 14
02:52 PM
- Mute
- Permalink
- Report
Hi Folks,
So, I've gotten myself into somewhat of a pickle. I have this part I need to make on my 3 axis CNC. I've managed to draw it in a way that tools can't actually reach certain surfaces. I'd like to modify this part so inside walls are oriented in line with the Z axis, as well as the holes around the part. I'm at a loss as to how to go about modifying the part. Would it be better if I just start from scratch?
I plan on using 3D surfacing toolpaths for the majority of the work and standard drilling cycles for the holes.
On the swept model in the second attached drawing, I modified it to work on the ends, it won't work on the sides now, and if I get it to work on the sides, well you get the point.
The 'Flange Sketch' in the first attached file is the profile I used originally and works on the sides.
Please let me know if further info or details would help; and what they would be.
Any and all advice would be greatly appreciated.
Thanks in advance
