I have tried using thin extrusion, however, some outlines won't extrude at all
4 REPLIES 4
nreyna18
262 Views, 4 Replies
Hi all, I am new to Fusion 360 and modeling in general, and I am trying to create a model of something I saw on the internet.
The problem I am running into is, there are areas (the top right "bow" looking thing) of my sketch which won't extrude correctly no matter what order I extrude them, or what settings I use.
Similarily, when I thin extrude the largest face, it gives me an extra border for the whiskers, I am unsure how to go about doing this.
I have watched tutorial and they've brought me this far but these are some problems I've run into.
my sketchmy sketchwhat I get after thin/reg extruding everythingwhat I get after thin/reg extruding everythingwhat I wantwhat I want
Tags (1)
4 REPLIES 4
hamid.sh.
in reply to: nreyna18
Please export your model to *.f3d and share it here to get better help.
Hamid
nreyna18
in reply to: hamid.sh.
Thank you for the advice! I attached the .f3d below!
davebYYPCU
Works here, don't know your size settings.
Build the line/s selected by clicking each one....
Might help.....
jeff_strater
I was able to get the bow to work by selecting curves, not the closed profiles:
But, I did not explore any farther than that
Jeff Strater
Engineering Director
Technology Administrators
