- Mute
- Permalink
- Report
In this simple example (attached) I draw a circle on one plane and then a circle on another plane.
The first circle is projected to the second sketch automatically. I cannot avoid or remove the projection nor turn it into a construction line.
The projection interferes with a loft from circle 1 to circle 2.
What to do?
EDIT.
It seems that I got this auto projection because I created the offset construction plane from circle1 and not from the XY base plane.
EDIT 2
I can delete or change the projected circle if I alter the view from flat XY to perspective while editing the sketch.
Somethig about selection options I shold learn?
