I could not patch my sketch
Hello . I have made a sketch through control point spline. The problem which i am facing is that i could not patch it.  I am attaching the file. Plz Try to resolve the problem . Thanks
jhackney1972
Surface extrude the sketch as a body and then create your patch on that as another body.  Then you can go back and make the surface extrude invisible.  Model is attached.
John Hackney, Retired
mango.freund
hi @Anonymous ------------- greetings mango
Hello @jhackney1972 . I want to patch my sketch again after mirror but i could not select the mirror sketch .plz help me.2.PNG
greetings @mango.freund . I want to patch my sketch again but i could not select the mirror sketch. Plz tell me about the possible solution,
TrippyLighting
What you are attempting to do is not a good idea.
In general, the patch command in Fusion 360 creates pretty horrible surfaces. Imagine the spline you created (which has way too many control points) is a steel wire rim and you are trying to stretch a very stiff table cloth over it.
The approach you are taking with his chair in the other thread you posted has much better change of success and uses the right techniques. Except the patch maybe but it seems to work OK in that instance.
Hello @jhackney1972 I forgot to attach the file for the second patch . I am attaching the file here. Thanks.
