I cant create a drawing
Message 1 of 9
the face that you see is selected and the one to the right of it will not allow me to draw on them, I also can not select them in cam. does anyone have any idea why that is? I am attempting to machine out a dado that follows the arch of that face around the perimeter.
Replies (8)
Message 2 of 9
JDMather
Your title say "drawing", but I suspect that you really mean model sketch.
If so, is the face planar?
Can you project from a planar sketch?
Can you sketch a profile on a perpendicular plane for Sweep?
Message 3 of 9
SaeedHamza
You mean sketch
If iit's not letting you create a sketch on that face , it means it's not flat
In that case, create an offset plane from that face, and create a sketch on it
then use the extrude from object command and select the face so that the extrusion takes the shape of the curved face you want to extrude from
Regards
Saeed
Saeed Hamza
Message 4 of 9
that's part of my issue as well, it will not allow me to create an offset plane from that face, and if I create and offset plane from another plane it will not allow me to extrude to an object
Message 5 of 9
SaeedHamza
planes are always flat, so create a horizontal one
Create one from the origin and drag it up, then sketch on it and extrude from object
if it didn't work with you, tell me and I'll create a screencast right away for you
Regards
Saeed
Saeed Hamza
Message 6 of 9
davebYYPCU
Have you tried the sweep command, you can use the edge of that face for the path, but you will need 3d sketches to work with that / any curved face.
Might help...
Message 7 of 9
SaeedHamza
Check this please
Saeed
Saeed Hamza
Message 8 of 9
so this was a great help! i have split the face but now it will not allow me to do anything with it. here is a link to what I have done to this point, http://a360.co/2rY1Eoz. what I am trying to do is do an extrude cut down about .5" from the sketch that you helped me project to the outside of the body.
I appreciate you help on this.
Message 9 of 9
youre awesome! I was able to use push pull and get it cut. thanks for all of your help!!
