I can't run my Fusion 360
Hi there,
I installed the fusion 360 but when I want to run the program a pop up indicates that the time zone appear to be incorrect.  I looked into the control panel and I changed my time zone tu UTC but still not working.
What can I do?
Regards
Francisco
Hi, I just had the same problem (Windows 8), and believe what solved it was going to the bottom left windows button, and in search field typing "date and time settings" choosing the first option, and turning on "adjust for daylight savings time automatically".  Incidentally I also had "set time automatically" turned off, and because of apparently a bad internal clock had to manually adjust time that was showing wrong for my selected time zone.
Good luck!
Jesse
