I can't move any offset plane
ameer.husseinFRRM5
ameer.husseinFRRM5
after new update I can't move any offset plane  with move options and key M
jeff_strater
workplanes have never been able to be moved using the Move command, in a Parametric design.  This has not changed in years.
Jeff Strater
Engineering Director
ameer.husseinFRRM5
No dear work planes have been able to be moved using the Move command before last update plz check this video
move and rotate also
ameer.husseinFRRM5
also copy command for skitch can't make copy
jeff_strater
That video was made from a Direct Modeling design.  There is no timeline.  In a history-based, Parametric design, you have NEVER been able to move/rotate a workplane.
Jeff Strater
jeff_strater
see previous answer - same thing here.  You cannot copy/paste a sketch in a Parametric design, and have never been able to.
Jeff Strater
TheCADWhisperer
@ameer.husseinFRRM5 wrote:
... I can't move any offset plane  with move options and key M
In a parametric design if you want to change the Offset distance - double click (or right click Edit Feature) on the node in the Timeline.
