i am trying to turn a complex shell into a thickness of 5mm
carlweitman50
Message 1 of 43
carlweitman50
I am trying to turn a complex shell into a thickness of 5mm. I have tried everything but i cant solve it. The design has no warnings so thats propably not the problem. Is there someone who maybe could help me out.
Replies (42)
Message 2 of 43
TheCADWhisperer
@carlweitman50
Examine the Attached file...
Message 3 of 43
carlweitman50
yes i can see. Where do you want to go with this?
Message 4 of 43
carlweitman50
yes i can see where do you want to got with this?
Message 5 of 43
carlweitman50
Yes i can see. What do you want to point out with this?
Message 6 of 43
davebYYPCU
Bottom of the window needs to be joined to the.top of the nose.
Moght help…..
Message 7 of 43
carlweitman50
Maybe do a loft with support rails?
Message 8 of 43
davebYYPCU
I can only comment on the pics in the discussion.
If the original body was solid there is an air gap to fix,
if the outside body is as Whisperer shows, then Stitch the seam.
Might help…
Message 9 of 43
carlweitman50
Tried it but stitching didnt work. However i cerater Lines 5mm in befors i did the original loft and then i lofted which worked perfectly. How do i fill in the profile?
Message 10 of 43
carlweitman50
Okay didnt work. Do you have any idea on how to connect then. Surface stitch didnt work and loft didnt work either
Message 11 of 43
davebYYPCU
I can not access the file, (travelling until Sunday)
will check it out at that time unless others get it fixed.
Might help….
Message 12 of 43
carlweitman50
Ok thanks!
Message 13 of 43
davebYYPCU
Checked the file.  At 200mm diameter, you will need some windscreen detail.
Most windscreens are flat.
This wavy window is likely contributing to the failed thicken.
To assist further, need to know more of the Design Intent, 3d printed, static or flying model?
Message 14 of 43
carlweitman50
it Will be 3d printed and Will be a flying model.
Message 15 of 43
davebYYPCU
Incorporating full size details, helps with avoiding the reinvention of these details in a model.
You have horizontal window sketch lines, that are curved.
These have flat panels and are segmented.
Might help...
Message 16 of 43
carlweitman50
Probably not because then i would have to scale it. Im making an rc airplane but the windows are not too curved and i used a straight line in the loft. Im not trying to do anything too fancy. Only thing that matters is aerodynamics
Message 17 of 43
wersy
If I had known how much rework it would involve, I wouldn't have started.
Of course, that's not a solution.
Message 18 of 43
carlweitman50
Hello. Very many thanks to the help. However if you look closely on the top of the window, there is unfortunately an uneven shape. This is problematic because then i cant join them and properly print them. Very many thanks tho, and i would greatly appreciate if you maybe took a look at the problem.
Carl
Message 19 of 43
TheCADWhisperer
@carlweitman50
Does your slicer have an option to set wall thickness
or
could you use MeshMixer to Shell a solid?
Either technique would not require a modeled Shell.
Message 20 of 43
carlweitman50
i can check
