I am trying to put a curved pipe through a solid object.
FacebookGroupMember
FacebookGroupMember
Hi. I am trying to put a curved pipe through a solid object. Any ideas?
Tried all the obvious.
FacebookGroupMember
Use the move tool to place it where you want then use the combine tool.
FacebookGroupMember
Set up the two objects as components, place where you want it, use the join function and cut setting. Select the solid object first, then the pipe. It should turn red.
FacebookGroupMember
Michael Strivelli
And check the "Keep tools" box.
FacebookGroupMember
Michael Strivelli You meant "Combine" and not "Join", right ?
g-andresen
please share the file.*
So we see what you are talking about.
günther
* File > export > save as f3d on local drive > attach to next post
