Creating A Swept Angle
fprice3
fprice3
Hi I am new to Fusion 360 and can't figure out how to create this angle shown in red. I can make an inverted angle that's radius faces the other way but not when it's the way it is. Also I can't find how to sweep this angle to go around the path of a circle. There might be an obvious answer to this but I can't seem to work it out so any help would be very much appreciated 🙂
PinRudolf
Hey, check out the modify commands; there is a command there that's called Fillet. The fillet command can take material away but it can also add material in existing corners. 🙂
g-andresen
In which mode do you work? > Sketch, Solid ...?
Please share the file.
File > export > save as f3d on local device  > attach it to the next post.
günther
jhackney1972
I will make a guess here that you are trying to place a fillet between two bodies and it is being placed inside instead of outside as you desire.  Take a look at the Screencast and note how the fillet in incorrect when I have two bodies but is correct when I only have one.  As requested, please attach your model for absolute proof and diagnosis.
John Hackney, Retired
