I am trying to make an inverse mirror of a body
cnctv
Message 1 of 8
cnctv
Ok I have a buddy who would like a drill/holding jig for a lower. So I figured I could project the plane and create a inverse of the body but I have not been able to do this. So I will post the file and a screenshot of what I am wanting to do and if someone could;e guide me I sure would appreciate it.
Basically the area in red I need to mill a plate that will fit against the model on both sides so it can be bolted thought the hole in the upper left and through the bottom. enabling it to be mounted in a vise and drill the holes.
Replies (7)
Message 2 of 8
melisa.kaner
Hi @cnctv !
Just to make sure I'm understanding here,  you would like the 'reverse' of your geometry there? Is this something that can be done by using the Combine tool (boolean cut)? By creating a virtual stock, you can combine>cut your virtual stock with your jig. This would create the inverse geometry you desire.
Let us know if this is what you needed?
Melisa Kaner
Product Manager - Fusion Electronics. Please DM me for Fusion Electronics feedback!
Message 3 of 8
cnctv
Anychance you can show me this or have a write up on how. I am still learning Fusion so...LOL
 and what I am needing is like if you were to push putty on the surface, so i guess yes the reverse geometry is what it would be.
Message 4 of 8
melisa.kaner
Hi @cnctv ,
Sure! I'm just uploading a Screencast now for you.
Melisa Kaner
Message 5 of 8
melisa.kaner
Hi @cnctv ,
Are you able to see this Screencast? Of course, you can dictate the boundaries of the 'virtual stock' I'm creating to your needs and edit the body however you like.
Does this make sense?
Melisa Kaner
Message 6 of 8
melisa.kaner
@cnctv
Apologies, here's actually attaching the Screencast!
Melisa Kaner
Message 7 of 8
cnctv
You folks are brilliant! I hope one day I know half as much as you guys...
THANKS!!!
Message 8 of 8
chrisplyler
That's an admirable goal, but unachievable.
@melisa.kaner  is a god with infinite knowledge. No human can have infinite knowledge.
