I am getting errors in simulation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to run a simulation on two components but the simulation isn't working.
The simulation comes up with these errors:
Warning: Warning: Some components/bodies in the Simulation Model have interferences
Click here to switch to 'Simplify Environment' and open 'Interferences'.
Warning: Warning: Visibility is turned off for some Bodies or Components. Hidden Bodies and Components will still participate in the Simulation Solve. To exclude Bodies and Components from the Simulation Solve, use the "Remove" tool in Simplify workspace.
Warning: Warning: Model contains 1 fully unconstrained group(s) in load case "Load Case1".
Click here to select 'Automatic Contacts'.
Click here to select 'Manual Contact'.
Click here to select 'DOF View' to inspect.
Warning: Warning: "Bolt Connector1" may be in conflict with "[S] Bonded1 [Clamp (1):1||Metal Stage:1]".
I have attached the file bellow.
Cheers.
