How would you model a zipper wallet?
Message 1 of 11
Greetings:
Does anyone have an idea how to model a zippered wallet as shown in the picture?  I am stuck at the zippered part which will be wrapped around the wallet.
Much appreciate for your time and help.
JM
Accepted solutions (3)
Replies (10)
Message 2 of 11
TrippyLighting
Pattern along a path is likely the tool of choice for the zipper.
Message 3 of 11
tdoJLDMA
Thank you for your suggestion.  I will look into this.
Message 4 of 11
TheCADWhisperer
Split Face and texture Appearance would be the easy way if you don't need actual geometry and don't zoom in too close.
Attach your *.f3d file here if you can't figure it out.
Message 5 of 11
Sorry, I didn't get your design intent.
Message 6 of 11
sanket223.patil
First I created the two zip elements and then I pattern them along one direction . And where you needed the zip to turn , I created a sketch for a path so the zip will pattern along the path .
Sanket Patil
Mechanical Engineering
Expert Elite
Message 7 of 11
melvinbrian3d
nice... in addition to you... i think u can create a middle construction plate and project the top path, and then Pattern along the project path
MelvinBrian3D
Message 8 of 11
melvinbrian3d
something like this...
MelvinBrian3D
Message 9 of 11
melvinbrian3d
I hope you like it
MelvinBrian3D
Message 10 of 11
Message 11 of 11
melvinbrian3d
I create a sketch and draw the two teeth
then I extrude them individually and apply a chamfer
then I Pattern the features along the Path
I hope you like it
I will leave below the .Fd3 File
MelvinBrian3D
