Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How would I model this coffee distributor?
3 REPLIES 3
radicalgel
599 Views, 3 Replies
Can someone help me figure out how to model this coffee distributor in Fusion 360? Image attached below.
Labels (2)
3 REPLIES 3
laughingcreek
in reply to: radicalgel
here's one approach-
radicalgel
in reply to: laughingcreek
This is awesome! Thanks a lot. Quick question though, how did you decide on the angle of the line in the second sketch?
laughingcreek
@radicalgel wrote:
...how did you decide on the angle of the line in the second sketch?
not having any details about the part, I just eyeballed it.  That line, and the unconstrained (blue) line in the first sketch, set the angle and position for the extrude cutout.  I left them free so I could drag them around to make adjustments.  you should lock those down with dimensions at some point.
