Right it's a cultural project. Mix of indian and the Mamluk Dynasty (Like Islamic Geometry) and for the Indian, part, it will be designed as like a pottish design, with a similar design on the top. And then my own personal effect by making it work both ways (upside down and normaly)
For your curiosity with the water, When I make the bowl with Holes, I'll use Boolean subtraction with a normal Bowl to get those little gaps seperately to 3d print. Will then spray paint different colour, to input in. I want it to be optional on whther they can be in the bowl or not for my project. Like smthing you pop in...
For @TheCADWhisperer
Problem solved sort off, I think the circular pattern is what I need. I will try to make the design when I get some free time, by revolving a curved line for a bowl only 15 degrees, make a sketch of one row of the ovally thingies, use emboss tool too make it curve on surface (if doesn't curve on surface I'll use thicken) use trim offset (or engrave/extrude) then use the circular pattern tool, to make the full circle with that pattern and I'll do any chambers,chamfers and fillets before I circular patter. I will constrain starting sketch and add parameters to change size of the bowl, I'll figure out how to keep the parameters of the first row sketch with the bowl size along the way
I will report back to the thread if this works after hearing @TheCADWhisperer first advice, otherwise I will ask necessary question to proceed
Sleeeeepy Regards
Ricky🤣
