Refence lines between sketches
I have a sketch that has construction lines defined that i want to reference in another sketch. I have been trying to use project to copy the line from one sketch to another and have done this before successfully. For some reason in this situation when I select the target sketch and edit it the other sketches in my model go away so I can't select the line i'm looking to project (i.e. copy to the second sketch).
In the picture you can see the construction line i'm looking to "copy" or project from Sketch2 to Sketch 1. When I edit Sketch1 then Sketch2 will disappear so I can't select this line. I did a similar operation in my model from Sketch1(1) to Sketch2 and it worked so what is different about this operation? The line in question was projected from Sketch1(1) is that the problem?
