How using Fusion 360 and keyshot for animation render
iguvendikler
Message 1 of 9
iguvendikler
Hello;
I am working about an animation in Fusion, you know fusion animation rendering is weak. I read some clues on web shortly "you can import your Fusion animation with every thing to keyshot."
bu I couldn't find any tutorial or something about it. There is some infos about render but not animation.
So, I installed keyshot trial, I export my data as .FBX (also I tried too FBX Exporter for Autodesk Fusion 360 Beta from app store) , When I import them to keyshot, my data looking well but there is nothing on timeline about object moves. Also, while I importing I click on pop-up about animaiton as well. But there is nothing on timeline.
Firstly, Is it true or urban legend Keyshot can import our Fusion animaiton data with timeline (object moves)
If true: How can it possible, any plug inn or detail, Is there anybody using this methods?
If urban legend, do you have any suggest about easly upgrade fusion 360 animation render visual quality. I mean easy way, If I find a way import my dusion total data, it will be short time, I do not want learn totally a new program about animation keyshot, bender...
Replies (8)
Message 2 of 9
TrippyLighting
I doubt that Keyshot imports any animation data from Fusion. Animation works often very differently from software to software.
Message 3 of 9
johnsonshiue
Hi! Have you taken a look at the Keyshot app on Fusion App store?
https://apps.autodesk.com/FUSION/en/Detail/Index?id=8834248675375692730&appLang=en&os=Win64
Many thanks!
Software Test Engineer
Message 4 of 9
iguvendikler
Yes
I have tried already too. It is working in fusion very well for just image render I couldn't work it for animation render. Are you using it? Can you render animation by keyshot in this way? How?
Message 5 of 9
johnsonshiue
Hi! I am sorry I never use this app. I was looking for a related app and this one came up. Based on the app description and discussions on other forums, this app does not render Fusion-created animation. It seems that you will need to export the Fusion animation to FBX. Then import it to Keyshot.
Many thanks!
Message 6 of 9
TrippyLighting
Many thanks!
I doubt that Fusion exports animation information to .fbx.
Message 7 of 9
johnsonshiue
Hi @TrippyLighting,
Yes, you are right. Fusion by itself does not export to FBX. But there are other apps to help.
https://apps.autodesk.com/FUSION/en/List/Search?isAppSearch=True&searchboxstore=FUSION&facet=&collec...
Many thanks!
Message 8 of 9
iguvendikler
 tried "FBX Exporter for Autodesk Fusion 360 Beta" from app store. This one most to my aim, keyshot import it scene looking ok but show a lot of error in a pop-up and timeline was empty again.
Other two ones describtions looking not close to animation. I did not tried them.
Message 9 of 9
TrippyLighting
Hi @TrippyLighting,
Many thanks!
Fusion DOES export .fbx! I've used this many times, and I prefer that to .obj!
What I am saying is that I doubt that the exported .fbx includes animation data.
